Introdução
I wanted to clean the display part of my bread maker, but to reach that the first stage was to disassemble the lower part, where the belt drive could be replaced.
O que você precisa
Make sure the machine is not under power and
remove the inner container
Remove the screw on the left side of the hinge of the lid (whith a philips 1 screwdrive)
After the screw is removed, you can move the lid (in open position) to the other side and slide it off the hinge (removing the lid completely)
Turn the complete machine upside down
Remove the four (PH1) screws from the four rubber stands.
When all screws are removed from the bottom side, the metal cover can be simply lifted up, and the motor is visible
Uma outra pessoa concluiu este guia.
