Ir para o conteúdo principal
Panasonic ARC ES-LT3N Power Button Replacement
O que você precisa
  1. Panasonic ARC ES-LT3N Power Button Replacement, Back Casing: passo 1, imagem 1 %32 Panasonic ARC ES-LT3N Power Button Replacement, Back Casing: passo 1, imagem 2 %32
    • Flip the razor over so the back is facing you.
  2. Panasonic ARC ES-LT3N Power Button Replacement: passo 2, imagem 1 %32 Panasonic ARC ES-LT3N Power Button Replacement: passo 2, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the 6 mm screw just above the charger port.
  3. Panasonic ARC ES-LT3N Power Button Replacement: passo 3, imagem 1 %32 Panasonic ARC ES-LT3N Power Button Replacement: passo 3, imagem 2 %32
    • Slide the plastic cover at the bottom of the razor downward to remove.
  4. Panasonic ARC ES-LT3N Power Button Replacement: passo 4, imagem 1 %32 Panasonic ARC ES-LT3N Power Button Replacement: passo 4, imagem 2 %32
    • Lift up the rear casing from the bottom of the razor.
    • This may require you to gently pry it apart with you fingers.
    • Lift up the rear casing from the sides of the razor.
    • Pull rear casing up and off razor.
    • Be careful not to break any plastic!
  5. Panasonic ARC ES-LT3N Power Button Replacement, Battery: passo 5, imagem 1 %32
    • Using the Phillips 00 driver bit, remove six screws (12mm) from the battery case.
  6. Panasonic ARC ES-LT3N Power Button Replacement: passo 6, imagem 1 %32
    • Remove battery case.
  7. Panasonic ARC ES-LT3N Power Button Replacement: passo 7, imagem 1 %32 Panasonic ARC ES-LT3N Power Button Replacement: passo 7, imagem 2 %32
    • Remove old battery by lifting the battery up and left.
    • There are plastic brackets holding the battery on the right. Removing up and left ensures that the brackets will not be damaged and the battery will not come loose.
  8. Panasonic ARC ES-LT3N Power Button Replacement, Power Button: passo 8, imagem 1 %32 Panasonic ARC ES-LT3N Power Button Replacement, Power Button: passo 8, imagem 2 %32 Panasonic ARC ES-LT3N Power Button Replacement, Power Button: passo 8, imagem 3 %32
    • Remove the 8 mm screws directly below the lock switch.
  9. Panasonic ARC ES-LT3N Power Button Replacement: passo 9, imagem 1 %32 Panasonic ARC ES-LT3N Power Button Replacement: passo 9, imagem 2 %32 Panasonic ARC ES-LT3N Power Button Replacement: passo 9, imagem 3 %32
    • Push the lock switch upward and remove the 6 mm screw hidden beneath.
  10. Panasonic ARC ES-LT3N Power Button Replacement: passo 10, imagem 1 %32 Panasonic ARC ES-LT3N Power Button Replacement: passo 10, imagem 2 %32
    • Remove the lock switch by sliding it downward until it is out of place.
  11. Panasonic ARC ES-LT3N Power Button Replacement: passo 11, imagem 1 %32 Panasonic ARC ES-LT3N Power Button Replacement: passo 11, imagem 2 %32 Panasonic ARC ES-LT3N Power Button Replacement: passo 11, imagem 3 %32
    • Starting from the bottom, lift the front casing upward to separate the case from the device.
    • Continue to lift the device upward until you can pull the casing off.
    • It may take some wiggling or slight bending of the plastic to remove all the way.
  12. Panasonic ARC ES-LT3N Power Button Replacement: passo 12, imagem 1 %32 Panasonic ARC ES-LT3N Power Button Replacement: passo 12, imagem 2 %32 Panasonic ARC ES-LT3N Power Button Replacement: passo 12, imagem 3 %32
    • Remove the button.
Conclusão
Andrew Trainor
Membro desde: 03/05/17
603 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 443
