Ir para o conteúdo principal
Panasonic ARC ES-LT3N Battery Replacement
O que você precisa
  1. Panasonic ARC ES-LT3N Battery Replacement, Back Casing: passo 1, imagem 1 %32 Panasonic ARC ES-LT3N Battery Replacement, Back Casing: passo 1, imagem 2 %32
    • Flip the razor over so the back is facing you.
  2. Panasonic ARC ES-LT3N Battery Replacement: passo 2, imagem 1 %32 Panasonic ARC ES-LT3N Battery Replacement: passo 2, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the 6 mm screw just above the charger port.
  3. Panasonic ARC ES-LT3N Battery Replacement: passo 3, imagem 1 %32 Panasonic ARC ES-LT3N Battery Replacement: passo 3, imagem 2 %32
    • Slide the plastic cover at the bottom of the razor downward to remove.
  4. Panasonic ARC ES-LT3N Battery Replacement: passo 4, imagem 1 %32 Panasonic ARC ES-LT3N Battery Replacement: passo 4, imagem 2 %32
    • Lift up the rear casing from the bottom of the razor.
    • This may require you to gently pry it apart with you fingers.
    • Lift up the rear casing from the sides of the razor.
    • Pull rear casing up and off razor.
    • Be careful not to break any plastic!
  5. Panasonic ARC ES-LT3N Battery Replacement, Battery: passo 5, imagem 1 %32
    • Using the Phillips 00 driver bit, remove six screws (12mm) from the battery case.
  6. Panasonic ARC ES-LT3N Battery Replacement: passo 6, imagem 1 %32
    • Remove battery case.
  7. Panasonic ARC ES-LT3N Battery Replacement: passo 7, imagem 1 %32 Panasonic ARC ES-LT3N Battery Replacement: passo 7, imagem 2 %32
    • Remove old battery by lifting the battery up and left.
    • There are plastic brackets holding the battery on the right. Removing up and left ensures that the brackets will not be damaged and the battery will not come loose.
Conclusão
Andrew Trainor
Membro desde: 03/05/17
603 Reputação
Autoria de 5 guias
Equipe
Um comentário
Where does one actually find the replacement batteries though?
WooKstah - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 1,701
