Ir para o conteúdo principal
Palm v Battery Replacement
O que você precisa
  1. Palm v Battery Replacement, Outer Case: passo 1, imagem 1 %32
    • Lay device face down on surface.
  2. Palm v Battery Replacement: passo 2, imagem 1 %32 Palm v Battery Replacement: passo 2, imagem 2 %32
    • Heat the left and top edges with hairdryer for one minute.
    • Move hairdryer back and forth to evenly heat up surface.
    • Caution: directly heating the screen can melt or distort the screen.
  3. Palm v Battery Replacement: passo 3, imagem 1 %32
    • Use tweezers to hold Palm right side down on it's side.
    • Use a plastic opening tool to pry open front and back casing.
    • If you are unable to open you may need to heat with hairdryer for longer.
    • Be sure not to touch case directly with fingers, it will be hot!
  4. Palm v Battery Replacement: passo 4, imagem 1 %32
    • Leave plastic opening tools in between front and back casing.
    • Rotate Palm and repeat steps 2 and 3 for right and back edges.
  5. Palm v Battery Replacement: passo 5, imagem 1 %32 Palm v Battery Replacement: passo 5, imagem 2 %32 Palm v Battery Replacement: passo 5, imagem 3 %32
    • Now pry open front and back casing with plastic opening tools.
    • Separate front and back casing completely.
    • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
  6. Palm v Battery Replacement, Screen: passo 6, imagem 1 %32 Palm v Battery Replacement, Screen: passo 6, imagem 2 %32
    • In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
    • To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
    • Once the clamp is up you can use the tweezers to gently detach the ribbon.
  7. Palm v Battery Replacement: passo 7, imagem 1 %32 Palm v Battery Replacement: passo 7, imagem 2 %32 Palm v Battery Replacement: passo 7, imagem 3 %32
    • Now you must flip up the adjacent clamp as well, using tweezers like before.
    • After the clamp is flipped you can gently remove the second ribbon with tweezers.
  8. Palm v Battery Replacement: passo 8, imagem 1 %32 Palm v Battery Replacement: passo 8, imagem 2 %32
    • Before removing the screen you must detach one more wire, the battery connector.
    • Using the tweezers, squeeze the connector attached to the wire and genlty pull.
    • Do not pull from the wire.
  9. Palm v Battery Replacement: passo 9, imagem 1 %32
    • Now that both ribbons and the wire are disconeccted, you can apply a downward pressure to the battery. You will have to carefully rotate the frame so that the battery can go through.
  10. Palm v Battery Replacement, Battery: passo 10, imagem 1 %32 Palm v Battery Replacement, Battery: passo 10, imagem 2 %32
    • Lay screen face down so the battery is facing upwards.
    • Cover the upper back portion of the device so the battery is the only exposed part.
  11. Palm v Battery Replacement: passo 11, imagem 1 %32
    • Use the hairdryer to heat each side of the battery for at least 30 seconds.
  12. Palm v Battery Replacement: passo 12, imagem 1 %32 Palm v Battery Replacement: passo 12, imagem 2 %32
    • Using the tweezers or the spudger, pry off the battery from the screen.
    • If battery is not coming off, reheat sides and reattempt to remove.
Conclusão
3 outras pessoas executaram este guia.
Anthony Platt
Membro desde: 02/09/10
66 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 13-25, Maness Winter 2010 Membro de Cal Poly, Team 13-25, Maness Winter 2010
CPSU-MANESS-W10S13G25
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 35
Duração total: 10,148
