Ir para o conteúdo principal
Palm m500 button cover replacement
O que você precisa
  1. Palm m500 button cover replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the stylus from the side of the PDA by sliding it upwards.
  2. Palm m500 button cover replacement: passo 2, imagem 1 %32 Palm m500 button cover replacement: passo 2, imagem 2 %32
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
  3. Palm m500 button cover replacement: passo 3, imagem 1 %32 Palm m500 button cover replacement: passo 3, imagem 2 %32 Palm m500 button cover replacement: passo 3, imagem 3 %32
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
  4. Palm m500 button cover replacement, Battery: passo 4, imagem 1 %32 Palm m500 button cover replacement, Battery: passo 4, imagem 2 %32 Palm m500 button cover replacement, Battery: passo 4, imagem 3 %32
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
  5. Palm m500 button cover replacement, Motherboard: passo 5, imagem 1 %32 Palm m500 button cover replacement, Motherboard: passo 5, imagem 2 %32 Palm m500 button cover replacement, Motherboard: passo 5, imagem 3 %32
    • Use the plastic opening tool to pry the orange clamp away from the motherboard.
    • Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate.
    • Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
  6. Palm m500 button cover replacement, LCD Screen: passo 6, imagem 1 %32 Palm m500 button cover replacement, LCD Screen: passo 6, imagem 2 %32
    • Pull the LCD screen up from the bottom of the device using your forefinger.
    • The LCD screen will easily come away from the front panel.
  7. Palm m500 button cover replacement, button covers: passo 7, imagem 1 %32 Palm m500 button cover replacement, button covers: passo 7, imagem 2 %32
    • Gently remove the buttons from the front panel with your thumb and forefinger.
    • The buttons are not secured and should easily fall out.
Conclusão
Miles Johnson
Membro desde: 01/11/11
579 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 14-9, Forte Winter 2011 Membro de Cal Poly, Team 14-9, Forte Winter 2011
CPSU-FORTE-W11S14G9
Membros da 6
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 1,582
