Ir para o conteúdo principal
Palm m500 LCD Screen Replacement
O que você precisa
  1. Palm m500 LCD Screen Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the stylus from the side of the PDA by sliding it upwards.
    Pergunte ao FixBot
    Comentar
  2. Palm m500 LCD Screen Replacement: passo 2, imagem 1 %32 Palm m500 LCD Screen Replacement: passo 2, imagem 2 %32
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
    Pergunte ao FixBot
    Comentar
  3. Palm m500 LCD Screen Replacement: passo 3, imagem 1 %32 Palm m500 LCD Screen Replacement: passo 3, imagem 2 %32 Palm m500 LCD Screen Replacement: passo 3, imagem 3 %32
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
    Pergunte ao FixBot
    Comentar
  4. Palm m500 LCD Screen Replacement, Battery: passo 4, imagem 1 %32 Palm m500 LCD Screen Replacement, Battery: passo 4, imagem 2 %32 Palm m500 LCD Screen Replacement, Battery: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
    Pergunte ao FixBot
    Comentar
  5. Palm m500 LCD Screen Replacement, Motherboard: passo 5, imagem 1 %32 Palm m500 LCD Screen Replacement, Motherboard: passo 5, imagem 2 %32 Palm m500 LCD Screen Replacement, Motherboard: passo 5, imagem 3 %32
    • Use the plastic opening tool to pry the orange clamp away from the motherboard.
    • Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate.
    • Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
    Pergunte ao FixBot
    Comentar
  6. Palm m500 LCD Screen Replacement, LCD Screen: passo 6, imagem 1 %32 Palm m500 LCD Screen Replacement, LCD Screen: passo 6, imagem 2 %32
    • Pull the LCD screen up from the bottom of the device using your forefinger.
    • The LCD screen will easily come away from the front panel.
    Pergunte ao FixBot
    Comentar
Conclusão
Miles Johnson
Membro desde: 01/11/11
624 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 14-9, Forte Winter 2011 Membro de Cal Poly, Team 14-9, Forte Winter 2011
CPSU-FORTE-W11S14G9
6 Membros
Autoria de 6 guias
1Comentário do guia
The hardest part is getting the back plate off, I throttled my plastic spudger.
dpchoung - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 18
Últimos 30 dias: 57
Ao todo: 2,702
