Ir para o conteúdo principal
Palm m105 Batteries Replacement
  1. Palm m105 Batteries Replacement, Batteries: passo 1, imagem 1 %32
    • Press the latch on the battery door on the back of the device and pull outwards.
    • Back the device up if possible, you may lose all your data if there is no power for a little too long for it to retain it, make sure this is done quickly.
  2. Palm m105 Batteries Replacement: passo 2, imagem 1 %32
    • Install two AAA alkaline batteries into the battery compartment, placing the positive and negative ends of the battery in the correct positions. (Shown as a diagram inside the battery compartment)
    • Make sure to remove one battery at a time and replace with fresh battery. This will retain information on the device.
  3. Palm m105 Batteries Replacement: passo 3, imagem 1 %32
    • Place the battery door back into place on the back of the device; it will make a 'click' sound when properly reattached.
Conclusão
Erik Thompson
Membro desde: 10/04/11
31 Reputação
Autoria de 5 guias
Equipe
UW Stout, Team 1-3, Zhou Fall 2011 Membro de UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Membros
Autoria de 7 guias
2Comentários do guia
"Moderate difficulty"?? There's only three steps and two of them involve removing and reinstalling the battery door.
Gene Merritt - Responder Compartilhar
I have on that doesn't use batteries. It's a rechargeable one. Do you have any instructions on how to replace the internal battery?
deanplays - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 60
Ao todo: 1,626
