Ir para o conteúdo principal
Palm m 100 Cover Replacement
O que você precisa
  1. Palm m 100 Cover Replacement, Cover: passo 1, imagem 1 %32
    • Remove the batteries.
  2. Palm m 100 Cover Replacement: passo 2, imagem 1 %32
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Palm m 100 Cover Replacement: passo 3, imagem 1 %32 Palm m 100 Cover Replacement: passo 3, imagem 2 %32 Palm m 100 Cover Replacement: passo 3, imagem 3 %32
    • Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
  4. Palm m 100 Cover Replacement: passo 4, imagem 1 %32
    • Set aside broken cover, and replace with a new cover.
  5. Palm m 100 Cover Replacement: passo 5, imagem 1 %32
    • Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
  6. Palm m 100 Cover Replacement: passo 6, imagem 1 %32
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
Conclusão
Anne Carey
Membro desde: 10/25/11
1 Reputação
Autoria de 3 guias
Equipe
James Madison, Team 1-3, Allen Fall 2011 Membro de James Madison, Team 1-3, Allen Fall 2011
JMU-ALLEN-F11S1G3
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 537
