Ir para o conteúdo principal
Palm Zire 71 Battery Replacement
O que você precisa
  1. Palm Zire 71 Battery Replacement, Preparation: passo 1, imagem 1 %32
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Battery Replacement, Top Screws (2) Removal: passo 2, imagem 1 %32
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Battery Replacement, Bottom Screws (3) Removal: passo 3, imagem 1 %32
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Battery Replacement, Front Panel Removal: passo 4, imagem 1 %32 Palm Zire 71 Battery Replacement, Front Panel Removal: passo 4, imagem 2 %32
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Battery Replacement, Bracket and Speaker Removal: passo 5, imagem 1 %32 Palm Zire 71 Battery Replacement, Bracket and Speaker Removal: passo 5, imagem 2 %32
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Battery Replacement, Back Cover: passo 6, imagem 1 %32 Palm Zire 71 Battery Replacement, Back Cover: passo 6, imagem 2 %32
    • Slide the back cover off.
  7. Palm Zire 71 Battery Replacement, Battery: passo 7, imagem 1 %32
    • Remove the Philips #00 screw
    • Remove the sliver metal piece
  8. Palm Zire 71 Battery Replacement: passo 8, imagem 1 %32 Palm Zire 71 Battery Replacement: passo 8, imagem 2 %32
    • Remove the Philips screws #00
    • Remove the rear blue panel by prying both sides using the plastic opening tool
  9. Palm Zire 71 Battery Replacement: passo 9, imagem 1 %32 Palm Zire 71 Battery Replacement: passo 9, imagem 2 %32 Palm Zire 71 Battery Replacement: passo 9, imagem 3 %32
    • Remove the black plastic sticker
    • Pull the tap up to remove the metal cap
  10. Palm Zire 71 Battery Replacement: passo 10, imagem 1 %32 Palm Zire 71 Battery Replacement: passo 10, imagem 2 %32 Palm Zire 71 Battery Replacement: passo 10, imagem 3 %32
    • Remove the cable by pinching the sides and pulling
    • Pry off the battery with the plastic opening tool
    • Insert the new battery
Conclusão
7 outras pessoas executaram este guia.
Jinxian Jiang
Membro desde: 04/28/11
245 Reputação
Autoria de 3 guias
Equipe
CSU Los Angeles, Team 1-5, Nelson Spring 2011 Membro de CSU Los Angeles, Team 1-5, Nelson Spring 2011
CSULA-NELSON-S11S1G5
Membros da 3
Autoria de 6 guias
Um comentário
It's clear they just want you to throw it away when the battery dies. That was quite a chore getting the parts off and such without destroying the circuit board and that fine ribbon cable. Got it done though. No wifi I see. Too bad.
dnphoton - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 60
Duração total: 9,047
