Ir para o conteúdo principal
Palm Zire 31 Speaker Replacement
O que você precisa
  1. Palm Zire 31 Speaker Replacement, Case: passo 1, imagem 1 %32
    • Unscrew the two 7.35mm Torx T6 screws.
  2. Palm Zire 31 Speaker Replacement: passo 2, imagem 1 %32
    • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  3. Palm Zire 31 Speaker Replacement: passo 3, imagem 1 %32
    • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  4. Palm Zire 31 Speaker Replacement: passo 4, imagem 1 %32
    • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
  5. Palm Zire 31 Speaker Replacement, Speaker: passo 5, imagem 1 %32
    • The soldering iron heats up leads, wires, and everything else it touches that is metal. Leaving it on too long may damage the board or burn you.
    • Desolder the speaker wires and solder the new speaker in its place.
    • The black and red wires are connected to the two solder bulbs in the yellow box.
Conclusão
Gabe
Membro desde: 01/23/11
501 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-21, Amido Winter 2011 Membro de Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 593
