Introdução
Remove the screen for replacement or cleaning.
O que você precisa
Press the button on the back cover to release the battery cover.
Slide off the battery cover.
Remove the stylus by pulling up on the large top to reveal the top left case screw.
Pull away the black flap to reveal the top right case screw.
Using your fingers gently lift the display screen panel out of the casing by either grasping it from the back or popping it out of the front.
Quase terminado!
Conclusão
