Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Remove the back cover to reveal internal components, such as the circuit board, keyboard and screen.
O que você precisa
Press the button on the back cover to release the battery cover.
Slide off the battery cover.
Remove the stylus by pulling up on the large top to reveal the top left case screw.
Pull away the black flap to reveal the top right case screw.
Use the T5 screwdriver attachment to remove the 5 black/red back case screws marked by the red circles. These screws are 0.274 inches long.
Use the same T5 screwdriver attachment to remove the middle screw marked by the orange circle. It is shorter than the other screws at 0.121 inches in length.
