Introdução
Follow this guide to remove the keypad of the cell phone
O que você precisa
Press the button located just above the Sprint™ logo and then slide the cover down.
Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
Once the motherboard is removed, the LCD should be resting on the front case of the phone.
