Ir para o conteúdo principal
Palm Treo 700P Camera Replacement
O que você precisa
  1. Palm Treo 700P Camera Replacement, Battery: passo 1, imagem 1 %32 Palm Treo 700P Camera Replacement, Battery: passo 1, imagem 2 %32 Palm Treo 700P Camera Replacement, Battery: passo 1, imagem 3 %32
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Palm Treo 700P Camera Replacement: passo 2, imagem 1 %32 Palm Treo 700P Camera Replacement: passo 2, imagem 2 %32
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Palm Treo 700P Camera Replacement, Back Case: passo 3, imagem 1 %32
    • Remove the stylus from the phone.
  4. Palm Treo 700P Camera Replacement: passo 4, imagem 1 %32
    • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
  5. Palm Treo 700P Camera Replacement: passo 5, imagem 1 %32
    • Using the spudger, remove the small rubberized patch under the antenna.
  6. Palm Treo 700P Camera Replacement: passo 6, imagem 1 %32
    • Unscrew the last two screws using the previous screw driver.
  7. Palm Treo 700P Camera Replacement: passo 7, imagem 1 %32 Palm Treo 700P Camera Replacement: passo 7, imagem 2 %32
    • Using the plastic opening tool, gently separate the back case from the phone body.
  8. Palm Treo 700P Camera Replacement, Motherboard: passo 8, imagem 1 %32 Palm Treo 700P Camera Replacement, Motherboard: passo 8, imagem 2 %32 Palm Treo 700P Camera Replacement, Motherboard: passo 8, imagem 3 %32
    • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
  9. Palm Treo 700P Camera Replacement: passo 9, imagem 1 %32 Palm Treo 700P Camera Replacement: passo 9, imagem 2 %32 Palm Treo 700P Camera Replacement: passo 9, imagem 3 %32
    • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
    • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
  10. Palm Treo 700P Camera Replacement: passo 10, imagem 1 %32 Palm Treo 700P Camera Replacement: passo 10, imagem 2 %32
    • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
    • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
  11. Palm Treo 700P Camera Replacement: passo 11, imagem 1 %32 Palm Treo 700P Camera Replacement: passo 11, imagem 2 %32 Palm Treo 700P Camera Replacement: passo 11, imagem 3 %32
    • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
    • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
  12. Palm Treo 700P Camera Replacement, Camera: passo 12, imagem 1 %32
    • Using the plastic opening tool, loosen the metal camera holder.
  13. Palm Treo 700P Camera Replacement: passo 13, imagem 1 %32
    • Once the camera holder is loose, gently detach it from the camera.
Conclusão
Equipe
Cal Poly, Team 12-37, Regan Spring 2012 Membro de Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
Membros da 4
Autoria de 14 guias
Um comentário
Does anyone know where or how to get a developers guide or geeks guide to tearing this phone down completely? I have a number of these, as well as old Galaxy Note phones, a broken S7 etc. And I would love to have the blueprint to know how to hack a LTE antenae, and S7 camera into my treo palm 700p..Wouldn't that be awesome? I still like it better than the modern smart phone, and just lost use of it when my carrier killed CDMA last week> :-(
peterveri - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 536
