Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Palm Treo 680 screen replacement
O que você precisa
  1. Palm Treo 680 screen replacement, Battery: passo 1, imagem 1 %32 Palm Treo 680 screen replacement, Battery: passo 1, imagem 2 %32
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
    Donde puedo comprar un telefono palm
    lupem5635 - Responder
  2. Palm Treo 680 screen replacement: passo 2, imagem 1 %32
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 screen replacement, Back Panel: passo 3, imagem 1 %32 Palm Treo 680 screen replacement, Back Panel: passo 3, imagem 2 %32
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
    Use a T5 Torx screwdriver instead of a T6. T6 is too big.
    Rhebakah Thomas - Responder
    I found T5 too large as well. T4 seeems to work
    Absent Minded Professor - Responder
  4. Palm Treo 680 screen replacement: passo 4, imagem 1 %32 Palm Treo 680 screen replacement: passo 4, imagem 2 %32
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 screen replacement: passo 5, imagem 1 %32
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Palm Treo 680 screen replacement: passo 6, imagem 1 %32 Palm Treo 680 screen replacement: passo 6, imagem 2 %32 Palm Treo 680 screen replacement: passo 6, imagem 3 %32
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
  7. Palm Treo 680 screen replacement, LCD Screen and Touch Screen: passo 7, imagem 1 %32 Palm Treo 680 screen replacement, LCD Screen and Touch Screen: passo 7, imagem 2 %32 Palm Treo 680 screen replacement, LCD Screen and Touch Screen: passo 7, imagem 3 %32
    • Take the front the pannel and notice that the screen is attached by a piece of silver tape.
    • Using a pair of tweezers, carefully peel off this piece of silver tape.
    • Remove the screen from the front pannel.
  8. Palm Treo 680 screen replacement: passo 8, imagem 1 %32 Palm Treo 680 screen replacement: passo 8, imagem 2 %32
    • Obtain a small metal spudger and flip up the 2 tiny plastic flaps that hold the tiny orange ribbons in place.
    • Do the same thing for the other flap on the opposite side.
  9. Palm Treo 680 screen replacement: passo 9, imagem 1 %32 Palm Treo 680 screen replacement: passo 9, imagem 2 %32 Palm Treo 680 screen replacement: passo 9, imagem 3 %32
    • Flip the screen over a 180 degrees and take off the metal piece that cushions the screen.
    • Flip the screen over another a 180 degrees and place pressure on the bottom ribbon (Where my left thumb is).
    • Slightly Pull apart the touch screen from the LCD screen by placing your thumbs where my thumbs are. DO NOT PULL THE TWO SCREENS COMPLETELY APART YET.
    • This part is tricky and might take some maneuvering and a little bit of force, but it is possible.
  10. Palm Treo 680 screen replacement: passo 10, imagem 1 %32 Palm Treo 680 screen replacement: passo 10, imagem 2 %32 Palm Treo 680 screen replacement: passo 10, imagem 3 %32
    • Move your thumbs to the other corner of the screen and repeat the same procedure in step 9.
    • Carefully peel the touch screen away from the LCD screen.
    • Now you should have both the touch screen and LCD screen detached from one another.
Conclusão
Maiya123
Membro desde: 10/22/09
51 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 6-4, Maness Fall 2009 Membro de Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
Membros da 4
Autoria de 12 guias
2 comentários
where can i get the new touch scree, actually my mobile has fallen down and broken the touch scree. i am a resident in India, Andhra Pradesh, Hyderabad........at Ramkote.... please give me message at chinthala.prasad@yahoo.com please
chinthalaprasad - Responder
These are very nice instructions. They are clear and detailed for anyone to follow. Thanks for putting together the steps and sharing it.
I have not tried all steps completely yet. But will do so. I will left with probably a question what to do with touch screen. My phone has
never fallen down nor damaged. It worked perfectly well and one fine day, touch screen stopped working. In any case, I will try.
RJ
Ravi Joshi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 6,443
