Introdução
This shows you how to replace a faulty microphone for the Palm Treo 680.
O que você precisa
Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
Remove the stylus in order to access the screw.
Remove the 27mm top-left screw using a T6 Torx screwdriver.
Using a pair of tweezers, grasp the blue rubber microphone.
Pull the rubber microphone up and back to remove it.
Now you have successfully removed the microphone.
