Introdução
This is a guide that indicates how to replace a faulty microphone for the Palm Treo 680.
Ferramentas
Peças
Nenhum componente especificado.
Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
Remove the stylus in order to access the screw.
Remove the 27mm top-left screw using a T6 Torx screwdriver.
Using a pair of tweezers, grasp the blue rubber microphone.
Pull the rubber microphone up and back to remove it.
Now you have successfully removed the microphone.
2 outras pessoas concluíram este guia.
