Ir para o conteúdo principal
Introdução
This guide shows you how to take off the back panel to the Palm Treo 680 in order to reach the other components within side the phone.
  1. Remove the battery cover by pressing on the small rectangular button located on the back of the phone. Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Remove the battery by pulling it out towards you.
    • Remove the battery by pulling it out towards you.
  3. Remove the stylus in order to access the screw. Remove the 27mm top-left screw using a T6 Torx screwdriver.
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner. Remove the 27mm screw using the T6 Torx screwdriver.
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Turn the phone so the screen is facing the right side. Use a spudger to carefully separate the back panel from the front panel to access components inside the phone. Separate the covers from the left side of the device as indicated in the picture.
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
Conclusão
Maiya123
Membro desde: 22/10/2009
51 Reputação
6 Guias de autoria
Equipe
Cal Poly, Team 6-4, Maness Fall 2009 Membro de Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Membros
12 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,862
