Ir para o conteúdo principal
Palm Treo 680 Back Panel Replacement
O que você precisa
  1. Palm Treo 680 Back Panel Replacement, Battery: passo 1, imagem 1 %32 Palm Treo 680 Back Panel Replacement, Battery: passo 1, imagem 2 %32
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
    Pergunte ao FixBot
    Comentar
  2. Palm Treo 680 Back Panel Replacement: passo 2, imagem 1 %32
    • Remove the battery by pulling it out towards you.
    Pergunte ao FixBot
    Comentar
  3. Palm Treo 680 Back Panel Replacement, Back Panel: passo 3, imagem 1 %32 Palm Treo 680 Back Panel Replacement, Back Panel: passo 3, imagem 2 %32
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Palm Treo 680 Back Panel Replacement: passo 4, imagem 1 %32 Palm Treo 680 Back Panel Replacement: passo 4, imagem 2 %32
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
    Pergunte ao FixBot
    Comentar
  5. Palm Treo 680 Back Panel Replacement: passo 5, imagem 1 %32
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Palm Treo 680 Back Panel Replacement: passo 6, imagem 1 %32 Palm Treo 680 Back Panel Replacement: passo 6, imagem 2 %32 Palm Treo 680 Back Panel Replacement: passo 6, imagem 3 %32
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Maiya123
Membro desde: 10/22/09
84 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 6-4, Maness Fall 2009 Membro de Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 74
Ao todo: 3,434
