Ir para o conteúdo principal
Palm Treo 650 LCD Screen Replacement
O que você precisa
  1. Palm Treo 650 LCD Screen Replacement, Battery and Stylus: passo 1, imagem 1 %32
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 LCD Screen Replacement: passo 2, imagem 1 %32
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 LCD Screen Replacement: passo 3, imagem 1 %32 Palm Treo 650 LCD Screen Replacement: passo 3, imagem 2 %32
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 LCD Screen Replacement, Case: passo 4, imagem 1 %32
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Palm Treo 650 LCD Screen Replacement: passo 5, imagem 1 %32 Palm Treo 650 LCD Screen Replacement: passo 5, imagem 2 %32
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Palm Treo 650 LCD Screen Replacement: passo 6, imagem 1 %32
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Palm Treo 650 LCD Screen Replacement: passo 7, imagem 1 %32 Palm Treo 650 LCD Screen Replacement: passo 7, imagem 2 %32
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Palm Treo 650 LCD Screen Replacement, Motherboard: passo 8, imagem 1 %32 Palm Treo 650 LCD Screen Replacement, Motherboard: passo 8, imagem 2 %32 Palm Treo 650 LCD Screen Replacement, Motherboard: passo 8, imagem 3 %32
    • Disconnect the ribbon cable before removing the motherboard.
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
  9. Palm Treo 650 LCD Screen Replacement: passo 9, imagem 1 %32 Palm Treo 650 LCD Screen Replacement: passo 9, imagem 2 %32
    • Pull off the motherboard.
  10. Palm Treo 650 LCD Screen Replacement, LCD Screen: passo 10, imagem 1 %32 Palm Treo 650 LCD Screen Replacement, LCD Screen: passo 10, imagem 2 %32 Palm Treo 650 LCD Screen Replacement, LCD Screen: passo 10, imagem 3 %32
    • Lift up the LCD screen so that the ribbon strip connecting it to the motherboard can be accessed.
    • Only lift the screen high enough to access the ribbon cable.
  11. Palm Treo 650 LCD Screen Replacement: passo 11, imagem 1 %32 Palm Treo 650 LCD Screen Replacement: passo 11, imagem 2 %32
    • Pull out the orange ribbon strip.
    • Remove the LCD screen.
Conclusão
4 outras pessoas executaram este guia.
cgood
Membro desde: 10/28/09
134 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 19-3, Maness Fall 2009 Membro de Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 55
Ao todo: 5,478
