Ir para o conteúdo principal
Palm Treo 650 Keyboard Replacement
O que você precisa
  1. Palm Treo 650 Keyboard Replacement, Battery and Stylus: passo 1, imagem 1 %32
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
    Pergunte ao FixBot
    Comentar
  2. Palm Treo 650 Keyboard Replacement: passo 2, imagem 1 %32
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
    Pergunte ao FixBot
    Comentar
  3. Palm Treo 650 Keyboard Replacement: passo 3, imagem 1 %32 Palm Treo 650 Keyboard Replacement: passo 3, imagem 2 %32
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
    Pergunte ao FixBot
    Comentar
  4. Palm Treo 650 Keyboard Replacement, Case: passo 4, imagem 1 %32
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
    Pergunte ao FixBot
    Comentar
  5. Palm Treo 650 Keyboard Replacement: passo 5, imagem 1 %32 Palm Treo 650 Keyboard Replacement: passo 5, imagem 2 %32
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Palm Treo 650 Keyboard Replacement: passo 6, imagem 1 %32
    • Pull the antenna outward to remove the antenna from the body of the phone.
    Pergunte ao FixBot
    Comentar
  7. Palm Treo 650 Keyboard Replacement: passo 7, imagem 1 %32 Palm Treo 650 Keyboard Replacement: passo 7, imagem 2 %32
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
    Pergunte ao FixBot
    Comentar
  8. Palm Treo 650 Keyboard Replacement, Motherboard: passo 8, imagem 1 %32 Palm Treo 650 Keyboard Replacement, Motherboard: passo 8, imagem 2 %32 Palm Treo 650 Keyboard Replacement, Motherboard: passo 8, imagem 3 %32
    • Disconnect the ribbon cable before removing the motherboard.
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
    Pergunte ao FixBot
    Comentar
  9. Palm Treo 650 Keyboard Replacement: passo 9, imagem 1 %32 Palm Treo 650 Keyboard Replacement: passo 9, imagem 2 %32
    • Pull off the motherboard.
    Pergunte ao FixBot
    Comentar
  10. Palm Treo 650 Keyboard Replacement, Keyboard: passo 10, imagem 1 %32
    • Unscrew the two 3.2 mm screws with a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  11. Palm Treo 650 Keyboard Replacement: passo 11, imagem 1 %32
    • Pull off the circuit board.
    Pergunte ao FixBot
    Comentar
  12. Palm Treo 650 Keyboard Replacement: passo 12, imagem 1 %32
    • Remove the keypad for cleaning or replacing.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
cgood
Membro desde: 10/28/09
134 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 19-3, Maness Fall 2009 Membro de Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 32
Ao todo: 5,022
