Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Position the phone so the screen faces down.
Remove the stylus found on the back of the phone.
Hold the button in the middle of the phone's back to remove the battery cover.
Slide the cover down to remove it, and set the cover aside.
Lift the edge of the battery, separating contact points, and pull out as pictured.
Remove the round, rubber cover to expose a screw that will be removed in the next step.
Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
Pull the antenna outward to remove the antenna from the body of the phone.
Pry the back cover off using an iFixit opening tool.
Remove the two 3.75 mm screws.
Pull off the logic board.
Pry off the camera connector plug.
Remove the camera.
