Introdução
These steps will allow you to replace the screen with a new one.
O que você precisa
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
The screen is connected to the phone with an orange data cable.
Slide the spudger as close to the connection as possible.
Gently pull the spudger up and the cable should come out of the socket.
Quase terminado!
Conclusão
