Ir para o conteúdo principal
Palm Treo 600 Logic Board Replacement
O que você precisa
  1. Palm Treo 600 Logic Board Replacement, Back Case: passo 1, imagem 1 %32
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Logic Board Replacement: passo 2, imagem 1 %32 Palm Treo 600 Logic Board Replacement: passo 2, imagem 2 %32
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Logic Board Replacement: passo 3, imagem 1 %32 Palm Treo 600 Logic Board Replacement: passo 3, imagem 2 %32
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Logic Board Replacement, Motherboard: passo 4, imagem 1 %32
    • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
  5. Palm Treo 600 Logic Board Replacement: passo 5, imagem 1 %32
    • Lift up the silver casing.
    • Careful! The casing is connected to the body. Pull the casing up.
  6. Palm Treo 600 Logic Board Replacement: passo 6, imagem 1 %32
    • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
  7. Palm Treo 600 Logic Board Replacement: passo 7, imagem 1 %32 Palm Treo 600 Logic Board Replacement: passo 7, imagem 2 %32
    • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
Conclusão
Clement Poisson
Membro desde: 01/26/10
24 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 13-23, Maness Winter 2010 Membro de Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,502
