Introdução
Steps to follow if you want to replace the logic board. Also needed if you want to access the camera.
O que você precisa
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
Quase terminado!
Conclusão
