Ir para o conteúdo principal
Introdução
If your camera doesn't work and it needs to be replaced, this guide will come in handy.
  1. On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
    • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
  5. Lift up the silver casing.
    • Lift up the silver casing.
    • Careful! The casing is connected to the body. Pull the casing up.
  6. With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
    • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
  7. Use the spudger to lift the logic board from its socket.  Remove it from the rest of the phone. Use the spudger to lift the logic board from its socket.  Remove it from the rest of the phone.
    • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
  8. Using the flat end of the spudger, lift the metal case off of the camera. Using the flat end of the spudger, lift the metal case off of the camera.
    • Using the flat end of the spudger, lift the metal case off of the camera.
  9. Slide the flat end of the spudger between the printed circuit board and metal holder. Pop the camera up Pop the camera up
    • Slide the flat end of the spudger between the printed circuit board and metal holder.
    • Pop the camera up
Conclusão
Clement Poisson
Membro desde: 26/01/2010
24 Reputação
7 Guias de autoria
Equipe
Cal Poly, Team 13-23, Maness Winter 2010 Membro de Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Membros
16 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,506
