Ir para o conteúdo principal
Palm Treo 600 Battery Replacement
O que você precisa
  1. Palm Treo 600 Battery Replacement, Back Case: passo 1, imagem 1 %32
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Battery Replacement: passo 2, imagem 1 %32 Palm Treo 600 Battery Replacement: passo 2, imagem 2 %32
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Battery Replacement: passo 3, imagem 1 %32 Palm Treo 600 Battery Replacement: passo 3, imagem 2 %32
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Battery Replacement, Battery: passo 4, imagem 1 %32 Palm Treo 600 Battery Replacement, Battery: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using metal tweezers, unplug small white plug.
    • Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
  5. Palm Treo 600 Battery Replacement: passo 5, imagem 1 %32
    • Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
    • The battery may be glued to the phone.
Conclusão
Equipe
Cal Poly, Team 13-23, Maness Winter 2010 Membro de Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 62
Ao todo: 6,039
