Ir para o conteúdo principal
Palm Pre Speaker Replacement
O que você precisa
  1. Palm Pre Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
  2. Palm Pre Speaker Replacement: passo 2, imagem 1 %32
    • Carefully pull up on the tab to remove the current battery.
  3. Palm Pre Speaker Replacement, Speaker: passo 3, imagem 1 %32 Palm Pre Speaker Replacement, Speaker: passo 3, imagem 2 %32
    • Use the t4 screwdriver to remove all 6 of the 3.6mm long screws.
  4. Palm Pre Speaker Replacement: passo 4, imagem 1 %32 Palm Pre Speaker Replacement: passo 4, imagem 2 %32
    • Use the spudger to locate the crease at the bottom of the keyboard.
    • Carefully work your way around the phone separating the back frame from the keyboard.
  5. Palm Pre Speaker Replacement: passo 5, imagem 1 %32
    • Use tweezers to remove the DIV and GPS antennas from the back of the keyboard.
  6. Palm Pre Speaker Replacement: passo 6, imagem 1 %32
    • Use the spuger to pry out the speaker. It is magnetically connected so do not be afraid to use the necessary force.
    • Make sure to take note of the orientation of the speaker for re-installation.
    • Make sure not the puncture the screen on the outside of the back frame.
Conclusão
noha
Membro desde: 04/12/12
139 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 7-31, Maness Spring 2012 Membro de Cal Poly, Team 7-31, Maness Spring 2012
CPSU-MANESS-S12S7G31
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,155
