Ir para o conteúdo principal
Palm Pre Motherboard Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Palm Pre Motherboard Replacement, Antenna: passo 1, imagem 1 %32 Palm Pre Motherboard Replacement, Antenna: passo 1, imagem 2 %32
    • First the back panel must be removed to reveal the battery.
    • Remove the battery pack.
  2. Palm Pre Motherboard Replacement: passo 2, imagem 1 %32 Palm Pre Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the six T5 screws necessary to separate the backplate from the phone.
    • There is one screw in the upper right that is concealed by a small sticker labeled "Palm."
    • Additionally, there are interlocking tabs securing the back plate around the edges.
    • Use the opening tool to carefully go around the phone releasing these tabs.
  3. Palm Pre Motherboard Replacement: passo 3, imagem 1 %32 Palm Pre Motherboard Replacement: passo 3, imagem 2 %32
    • Lift the metal flap marked in red to reveal the antenna connectors.
    • Carefully pry these the antennas from their connections, this can be done quite easily.
    • Take note of which colored wire is attached to each connection. The white wire corresponds to GPS, while the black wire corresponds to DIV, or diversity antenna.
  4. Palm Pre Motherboard Replacement, PCB (Phone Circuit Board): passo 4, imagem 1 %32 Palm Pre Motherboard Replacement, PCB (Phone Circuit Board): passo 4, imagem 2 %32 Palm Pre Motherboard Replacement, PCB (Phone Circuit Board): passo 4, imagem 3 %32
    • With the backplate removed, we have easy access to the PCB.
    • Two connectors must be disconnected so that we can remove the PCB.
    • Gentle prying with the opening tool should easily separate the glued PCB from the rest of the phone.
  5. Palm Pre Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Once you have removed the PCB, you can proceed to removing the keyboard bezel.
    • To do this, use a spudger to gently lift off the plastic edging as shown. There are small plastic hooks attaching the bezel to the keyboard.
    • Be careful not to rip any of the loops on the keyboard.
  6. Palm Pre Motherboard Replacement: passo 6, imagem 1 %32 Palm Pre Motherboard Replacement: passo 6, imagem 2 %32 Palm Pre Motherboard Replacement: passo 6, imagem 3 %32
    • Now you are ready to pry the slider function from the back of the screen.
    • Remove the four screws. The bottom two screws are easier to see when the phone is slid about half open.
    • Again, use the spudger to pry around the edges loosening it until it comes apart.
    • There are several connectors still attaching these two pieces. Use the spudger to disconnect them on the screen.
  7. Palm Pre Motherboard Replacement: passo 7, imagem 1 %32 Palm Pre Motherboard Replacement: passo 7, imagem 2 %32
    • Next, remove four connectors to remove the mother board.
    • Use a spudger to gently pry the four connectors.
    • There is a yellow film over some of the connectors that must be removed prior to removing the connections.
    • After everything is disconnected, the mother board should lift out easily.
Conclusão
iDeleted
Membro desde: 07/07/10
2.101 Reputação
Autoria de 39 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 336
