Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Make sure your Palm Pre is turned off before disassembling the phone.
Snap off the back panel to reveal the battery.
Carefully pull up on the tab to remove the current battery.
Use the T5 Torx Screwdriver to remove the six screws holding the backing frame in place.
Locate the hinge that covers the black and white GPS and DIV antennas. (The hinge will be located in the red box as portrayed in the picture.)
Use a spudger to pry open the hinge.
Use tweezers to disconnect the antennas from the keypad control board.
Use a spudger to pry off the (black and yellow) back frame.
Find the small circuit board at the top right and desolder the wires that are connected to it.
