Ir para o conteúdo principal
Palm Pre Antenna Replacement
O que você precisa
  1. Palm Pre Antenna Replacement, Battery: passo 1, imagem 1 %32
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
    Pergunte ao FixBot
  2. Palm Pre Antenna Replacement: passo 2, imagem 1 %32
    • Carefully pull up on the tab to remove the current battery.
    Pergunte ao FixBot
  3. Palm Pre Antenna Replacement, Antenna: passo 3, imagem 1 %32 Palm Pre Antenna Replacement, Antenna: passo 3, imagem 2 %32
    • Use the T5 Torx Screwdriver to remove the six screws holding the backing frame in place.
    Pergunte ao FixBot
  4. Palm Pre Antenna Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Locate the hinge that covers the black and white GPS and DIV antennas. (The hinge will be located in the red box as portrayed in the picture.)
    • Use a spudger to pry open the hinge.
    • Use tweezers to disconnect the antennas from the keypad control board.
    Pergunte ao FixBot
  5. Palm Pre Antenna Replacement: passo 5, imagem 1 %32 Palm Pre Antenna Replacement: passo 5, imagem 2 %32
    • Use a spudger to pry off the (black and yellow) back frame.
    • Disregard the main part of the phone at this point and look only at the inside of the removed back frame. (You will need the main part of the phone for access to the keyboard and motherboard)
    Pergunte ao FixBot
  6. Palm Pre Antenna Replacement: passo 6, imagem 1 %32
    • Find the small circuit board at the top right and desolder the wires that are connected to it.
    • This step is only necessary for antenna removal.
    Pergunte ao FixBot
Conclusão
noha
Membro desde: 04/12/12
139 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 7-31, Maness Spring 2012 Membro de Cal Poly, Team 7-31, Maness Spring 2012
CPSU-MANESS-S12S7G31
3 Membros
Autoria de 28 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 53
Ao todo: 1,612
