Ir para o conteúdo principal
Palm Pre 2 Motherboard Replacement
O que você precisa
  1. Palm Pre 2 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Palm Pre 2 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Make sure your Palm Pre 2 is turned off before taking apart the phone.
    • Snap off the back panel to reveal the battery using the opening tool.
  2. Palm Pre 2 Motherboard Replacement: passo 2, imagem 1 %32 Palm Pre 2 Motherboard Replacement: passo 2, imagem 2 %32 Palm Pre 2 Motherboard Replacement: passo 2, imagem 3 %32
    • Pull on the tab to remove the battery.
  3. Palm Pre 2 Motherboard Replacement: passo 3, imagem 1 %32 Palm Pre 2 Motherboard Replacement: passo 3, imagem 2 %32
    • Use the T5 Torx Screwdriver to remove the six screws that hold the back of the frame in place.
  4. Palm Pre 2 Motherboard Replacement: passo 4, imagem 1 %32 Palm Pre 2 Motherboard Replacement: passo 4, imagem 2 %32
    • Use a spudger to open the hinge that covers the black and white GPS and DIV antennas (Reference the red box in the image).
    • Use tweezers to remove the two antennas from the keypad control board.
  5. Palm Pre 2 Motherboard Replacement: passo 5, imagem 1 %32 Palm Pre 2 Motherboard Replacement: passo 5, imagem 2 %32
    • Use the opening tool to pry off the (black and yellow) back frame.
  6. Palm Pre 2 Motherboard Replacement: passo 6, imagem 1 %32 Palm Pre 2 Motherboard Replacement: passo 6, imagem 2 %32 Palm Pre 2 Motherboard Replacement: passo 6, imagem 3 %32
    • Use the opening tool to remove the panel on the main part of the phone.
    • Use the tweezers to get access to remove the panel giving access to the cable connectors.
    • Remove the two ribbon cable connectors using the tweezers.
  7. Palm Pre 2 Motherboard Replacement: passo 7, imagem 1 %32
    • Use tweezers to separate the keyboard from the phone.
  8. Palm Pre 2 Motherboard Replacement: passo 8, imagem 1 %32 Palm Pre 2 Motherboard Replacement: passo 8, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the remaining 4 screws from the main portion of the phone.
    • Use an opening tool to remove the motherboard.
Conclusão
Cole Simmerman
Membro desde: 01/08/18
160 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G6, Freund Spring 2018 Membro de IUPUI, Team S1-G6, Freund Spring 2018
IUPUI-FREUND-S18S1G6
Membros da 2
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 257
