Ir para o conteúdo principal
Palm Pilot Professional 3com LCD Screen Replacement
O que você precisa
  1. Palm Pilot Professional 3com LCD Screen Replacement, Keypad: passo 1, imagem 1 %32
    • Unscrew the three screws on the back of the Palm Pilot.
    Pergunte ao FixBot
    Comentar
  2. Palm Pilot Professional 3com LCD Screen Replacement: passo 2, imagem 1 %32 Palm Pilot Professional 3com LCD Screen Replacement: passo 2, imagem 2 %32
    • Pull the back cover from the bottom of the device and separate the interlocking tabs on the top to remove the back cover.
    Pergunte ao FixBot
    Comentar
  3. Palm Pilot Professional 3com LCD Screen Replacement: passo 3, imagem 1 %32
    • The front plastic cover is now free to be removed from the rest of the device.
    Pergunte ao FixBot
    Comentar
  4. Palm Pilot Professional 3com LCD Screen Replacement: passo 4, imagem 1 %32
    • The keypad is now free to be removed from the rest of the device.
    Pergunte ao FixBot
    Comentar
  5. Palm Pilot Professional 3com LCD Screen Replacement, LCD Screen: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Looking at the back of the device hold one of the white tabs on the ribbon cable connector down and use tweezers to push in the other white tab toward the device at the same time.
    Pergunte ao FixBot
    Comentar
  6. Palm Pilot Professional 3com LCD Screen Replacement: passo 6, imagem 1 %32
    • The ribbon cable is now loose. Use the tweezers to carefully slide the ribbon cable out of the connector.
    Pergunte ao FixBot
    Comentar
  7. Palm Pilot Professional 3com LCD Screen Replacement: passo 7, imagem 1 %32 Palm Pilot Professional 3com LCD Screen Replacement: passo 7, imagem 2 %32
    • The screen is now disconnected from the rest of the device and can now be removed.
    Pergunte ao FixBot
    Comentar
Conclusão
Kevin Santos
Membro desde: 03/09/12
1 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 2-4, Benson Spring 2012 Membro de Clemson, Team 2-4, Benson Spring 2012
CLEM-BENSON-S12S2G4
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 56
Ao todo: 1,989
