Ir para o conteúdo principal
Palm IIIx Touch Screen Replacement
O que você precisa
  1. Palm IIIx Touch Screen Replacement, Battery: passo 1, imagem 1 %32
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Touch Screen Replacement: passo 2, imagem 1 %32
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Touch Screen Replacement: passo 3, imagem 1 %32
    • Remove the old batteries one at a time.
  4. Palm IIIx Touch Screen Replacement, Touch Screen: passo 4, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Touch Screen Replacement: passo 5, imagem 1 %32
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers.
  6. Palm IIIx Touch Screen Replacement: passo 6, imagem 1 %32
    • Hold the screen and front cover on its side, facing the screen inward as shown.
    • Position your hands so that you can push the screen outward with your thumbs.
    • Remove the screen by pushing outward with your thumbs. Use your index fingers to hold the front cover in place.
  7. Palm IIIx Touch Screen Replacement: passo 7, imagem 1 %32 Palm IIIx Touch Screen Replacement: passo 7, imagem 2 %32
    • Position the device with the screen facing down.
    • Locate the white ribbon wire on the left hand side of the device.
    • On either side of the ribbon wire are two white clasps. Gently push the two clasps away from the board (to the left).
  8. Palm IIIx Touch Screen Replacement: passo 8, imagem 1 %32
    • Detach the ribbon wire by gently pulling it out of its connector.
  9. Palm IIIx Touch Screen Replacement: passo 9, imagem 1 %32
    • Separate the motherboard from the screen.
  10. Palm IIIx Touch Screen Replacement: passo 10, imagem 1 %32 Palm IIIx Touch Screen Replacement: passo 10, imagem 2 %32
    • On the back of the screen near the top right corner is a plastic filament:
    • Gently lift up on the two brown clasps on either side of the filament connector as shown.
    • Using a thin, blunt object (a toothpick works well), slide it under the plastic filament and lift up to detach the filament from its connector.
  11. Palm IIIx Touch Screen Replacement: passo 11, imagem 1 %32
    • Insert a spudger tool between the metal backing and the glass cover piece, as shown.
    • Run the spudger along the edge of the screen until the screen is lifted and can be removed.
    • Replace or clean as needed.
Conclusão
Uma outra pessoa concluiu este guia.
David Haskell
Membro desde: 01/21/10
44 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 14-43, Regan Winter 2010 Membro de Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 2,433
