Ir para o conteúdo principal
Palm IIIx Front Button Cluster Replacement
O que você precisa
  1. Palm IIIx Front Button Cluster Replacement, Battery: passo 1, imagem 1 %32
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Front Button Cluster Replacement: passo 2, imagem 1 %32
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Front Button Cluster Replacement: passo 3, imagem 1 %32
    • Remove the old batteries one at a time.
  4. Palm IIIx Front Button Cluster Replacement, Front Button Cluster: passo 4, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Front Button Cluster Replacement: passo 5, imagem 1 %32
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers
  6. Palm IIIx Front Button Cluster Replacement: passo 6, imagem 1 %32
    • Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
    • Position your hands so you can push the screen outward with your thumbs.
    • Remove the front cover by gently pushing outward with your thumbs. Use your index fingers to pull back on the front cover.
  7. Palm IIIx Front Button Cluster Replacement: passo 7, imagem 1 %32
    • Remove cluster by pulling on the rubber backing.
    • Clean, repair, and/or replace as neccessary.
Conclusão
David Haskell
Membro desde: 01/21/10
44 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 14-43, Regan Winter 2010 Membro de Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 1,351
