Introdução
A guide to replace a damaged, lost, or broken button cluster.
O que você precisa
Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
Position your hands so you can push the screen outward with your thumbs.
Remove the front cover by gently pushing outward with your thumbs. Use your index fingers to pull back on the front cover.
