Ir para o conteúdo principal
Pacific Image Electronics CS3600 Motor Replacement
O que você precisa
  1. Pacific Image Electronics CS3600 Motor Replacement, Motor: passo 1, imagem 1 %32 Pacific Image Electronics CS3600 Motor Replacement, Motor: passo 1, imagem 2 %32
    • To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
  2. Pacific Image Electronics CS3600 Motor Replacement: passo 2, imagem 1 %32
    • Next, remove the 5 9mm x 5mm screws from the circled spots with a Phillips J1 screwdriver.
  3. Pacific Image Electronics CS3600 Motor Replacement: passo 3, imagem 1 %32
    • Once the screws are removed, carefully lift the motor casing out of the device.
    • The plastic piece circled acts as a clamp, lift the casing up and towards you to detach the casing.
  4. Pacific Image Electronics CS3600 Motor Replacement: passo 4, imagem 1 %32 Pacific Image Electronics CS3600 Motor Replacement: passo 4, imagem 2 %32
    • Now, with the motor casing in hand, remove the two 9mm x 5mm screw and washer at the top of the motor casing using a J1 screwdriver.
    • Gently pull the motor away from the casing to expose the wires.
  5. Pacific Image Electronics CS3600 Motor Replacement: passo 5, imagem 1 %32
    • Carefully desolder the wires from their contact point on the circuit board.
    • You have now successfully removed the motor!
Conclusão
Alessia Carlton
Membro desde: 03/21/17
201 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team S46-G2, Bennett Spring 2017 Membro de Texas Tech, Team S46-G2, Bennett Spring 2017
TTU-BENNETT-S17S46G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 266
