Introdução
Bicycle chains sometimes need to be removed for maintenance or replacement. To make this process easier, bicycle chains sometimes include a master link, which is easier to open and close than normal links. This guide details how to replace a chain on a Pacific Cycle R4046WMB using a master link.
O que você precisa
Set the chain onto the same rear gear you removed the previous chain from earlier.
Thread the chain down and around the first derailleur gear...
...then between the two derailleur gears...
...then around the other derailleur gear.
Be sure to thread the chain through the chain guard, rather than over it.
