Introdução
Did you drop your PSP? If your LCD is broken for any reason, you're in luck! This guide will show you how to replace that LCD with a brand new one.
Ferramentas
Peças
Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
Lift the battery out of the PSP.
Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
Home bar cable
Microphone cable
LCD display data cable
Touchscreen cable
After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
10 outras pessoas concluíram este guia.
