Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Guide for removing the UMD Drive of a Sony PSP-3000
  1. Place the PSP face down and locate the battery cover on the left side of the device. Lift and remove the battery cover to reveal the battery. Remove the battery.
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    This will end your warranty, so do it on your own risk!
    Paweł Kasztura - Responder
    Even though warranties are long expired on these things.
    Vincent C. -
    “IF” your on this Site “I FIX IT(tm) to lean how to repair something on your own… you “Should NOT” be too concerned about warranty any longer, as if you were .. for your iPhone or Pad etc… you would have taken it to the supplier.. No??
    Barry Goian - Responder
  3. Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver. Two are located behind the battery's warranty sticker.
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. Next, unscrew the two screws located at the top of the PSP.
    • Next, unscrew the two screws located at the top of the PSP.
  5. Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    “DON’T” forget to put your screws separately on a mag mat (Or sticky tape) so to 1) Not loose them & 2) Remember where they go as they may be of differing sizes. (Refer time the pictures also helps, but you can take a pic on your camera as you go to remind you also.
  6. Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
 Remove the front casing completely.
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    J’ai récemment fait cette réparation et le boîtier avant ne voulait pas venir à condition d’enlever les deux vis sur le boîtier arrière au niveau du joystick et de la croix directionnelle. Il manque donc selon moi une partie mais je peux me tromper !
    Valentin Boileau - Responder
  7. Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
  8. Slowly lift the LCD screen off the PSP starting at the top edge corner. Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
    Attention à cette partie où l’écran est un peu bloqué dans le coin inférieur droit, il faut donner un peu de jeu vers la gauche pour le décaler et le retirer plus facilement.
  9. Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail. Pull all four ribbon cables out.
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
    For anyone struggling to get the screen’s smaller ribbon cable back in, don’t be too afraid to use tweezers to pull on the little tabs. It has to go in a good half way (of the darker area) in order for you to latch it without it falling back out.
    Tom - Responder
  10. Remove the metal tab that lies above the LCD screen.
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
  11. Remove the screw securing 'L' trigger to the PSP.
    • Remove the screw securing 'L' trigger to the PSP.
  12. Remove the white plastic piece that holds the 'L' trigger in place.
    • Remove the white plastic piece that holds the 'L' trigger in place.
  13. Remove the 'L' trigger from the PSP.
    • Remove the 'L' trigger from the PSP.
  14. Remove the screw securing the 'R' trigger.
    • Remove the screw securing the 'R' trigger.
  15. Remove the white plastic piece that holds the 'R' trigger in place.
    • Remove the white plastic piece that holds the 'R' trigger in place.
  16. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  17. Remove the 'R' trigger from the PSP.
    • Remove the 'R' trigger from the PSP.
  18. Remove the screw from the bottom left edge of the PSP.
    • Remove the screw from the bottom left edge of the PSP.
  19. Being careful not to break the ribbon cable, use the spudger to peel the adhesive button of the the 'L' trigger off the PSP.
    • Being careful not to break the ribbon cable, use the spudger to peel the adhesive button of the the 'L' trigger off the PSP.
    Being careful not to break the ribbon cable, use the spudger to peel the adhesive button of the 'L' trigger off the PSP.
    buzinon - Responder
  20. Using a fingernail or spudger, flip up the retaining bracket on the d-pad and 'L' trigger ribbon cable. Lift the black plastic bracket along with the d-pad contact pad, disconnecting the ribbon cable as you lift.
    • Using a fingernail or spudger, flip up the retaining bracket on the d-pad and 'L' trigger ribbon cable.
    • Lift the black plastic bracket along with the d-pad contact pad, disconnecting the ribbon cable as you lift.
    Be careful - the memory card should be taken out by now. If not, the d-pad assembly will not come out. You can safely remove it if you forgot though.
    Kris - Responder
  21. Remove the cable from the connector and remove the entire black piece from the PSP.
    • Remove the cable from the connector and remove the entire black piece from the PSP.
  22. Remove the screw holding the analog stick in place.
    • Remove the screw holding the analog stick in place.
  23. Flip up the lock on the analog sticks ribbon cable. Remove the analog stick from the PSP.
    • Flip up the lock on the analog sticks ribbon cable.
    • Remove the analog stick from the PSP.
  24. Flip up the lock and detach the ribbon cable above the power jack.
    • Flip up the lock and detach the ribbon cable above the power jack.
  25. Remove the screw from the power jack.
    • Remove the screw from the power jack.
  26. Carefully bend back the black tab holding the power jack in place and start pulling the jack up to release it from this clip.
    • Carefully bend back the black tab holding the power jack in place and start pulling the jack up to release it from this clip.
    The plastic tab in this step is very fragile. Use care when bending the plastic tab back.
    Kris - Responder
  27. Pull the plug connecting the power jack to the motherboard.
    • Pull the plug connecting the power jack to the motherboard.
    • Remove the power jack.
  28. Push the black tab at the bottom of the speaker to pop the speaker out of place, and remove the speaker. The speaker is spring loaded, so be sure to keep an eye on it in case it starts doing flips into the air when you push the tab.  Be careful not to lose or damage it!
    • Push the black tab at the bottom of the speaker to pop the speaker out of place, and remove the speaker.
    • The speaker is spring loaded, so be sure to keep an eye on it in case it starts doing flips into the air when you push the tab. Be careful not to lose or damage it!
    • Make sure the new/replacement speaker does not spring out during reassembly.
  29. Remove the cable carefully by lifting upwards from port attached to the motherboard .
    • Remove the cable carefully by lifting upwards from port attached to the motherboard .
  30. Flip up both of the locks and remove   both cables as shown
    • Flip up both of the locks and remove both cables as shown
  31. Flip up the lock and remove the  ribbon cable located at the bottom edge of the PSP.
    • Flip up the lock and remove the ribbon cable located at the bottom edge of the PSP.
  32. Use a Phillips #00 screwdriver to remove the bottom left screw attached to the PSP
    • Use a Phillips #00 screwdriver to remove the bottom left screw attached to the PSP
  33. Remove the screw located at the top of the power switch panel. Gently lift and remove the panel from the switch side Gently lift and remove the panel from the switch side
    • Remove the screw located at the top of the power switch panel.
    • Gently lift and remove the panel from the switch side
  34. Lift  up and remove the silver rim on the right side of the PSP
    • Lift up and remove the silver rim on the right side of the PSP
  35. Lift up and remove the silver rim on the left side of the PSP
    • Lift up and remove the silver rim on the left side of the PSP
  36. Starting from the bottom of the PSP, carefully lift up the motherboard without damaging the top port on the PSP
    • Starting from the bottom of the PSP, carefully lift up the motherboard without damaging the top port on the PSP
  37. Remove the motherboard from the PSP Remove the motherboard from the PSP
    • Remove the motherboard from the PSP
  38. On the bottom of the back of the PSP, pull the white plastic piece out.
    • On the bottom of the back of the PSP, pull the white plastic piece out.
  39. Use a spudger and pull the spring out and remove it from the PSP.
    • Use a spudger and pull the spring out and remove it from the PSP.
  40. Open the UMD (disk drive) and locate the two small black rubber squares wedged in the space between the casing and the metal drive hinge on either side. Pull these out using a pair of tweezers.
    • Open the UMD (disk drive) and locate the two small black rubber squares wedged in the space between the casing and the metal drive hinge on either side.
    • Pull these out using a pair of tweezers.
  41. Detach the metal piece from where it is attached to the body underneath the rubber pieces that were just removed.
    • Detach the metal piece from where it is attached to the body underneath the rubber pieces that were just removed.
    • The side of the piece that is closest to the door opening should now be loose. The whole piece should now be slid farther into the drive through the slots.
    • Once you slide the piece toward the back of the slots, the side that is still attached can be pried towards the center of the drive on each side to remove it from the slots on the door.
  42. Grabbing the PSP with both hands, gently pinch the UMD lid towards the right side (the side without the battery).
    • Grabbing the PSP with both hands, gently pinch the UMD lid towards the right side (the side without the battery).
    • Pull up and the the left side carefully to remove the lid from the PSP. (The casing may have to flex a little bit to allow this)
  43. Remove the four screw from the UMD drive.
    • Remove the four screw from the UMD drive.
  44. Remove the UMD Drive.
    • Remove the UMD Drive.
Conclusão
19 outras pessoas concluíram este guia.
mbnewsom
Membro desde: 28/10/2009
2.769 Reputação
11 Guias de autoria
Perfect!!! You forgot to mention 'GET YOUR EYEGLASSES' for the 50+ year old fathers that have to help on this procedure!!!! Man, oh man, are those parts small and delicate!!!! GREAT tutorial, than you very much! Blind in Boston.
Rosebud Mosaics - Responder
The tutorial was great btw, however after assembling everything into my new blue Mod i was left with a white plastic piece and a spring witch is in my psp 3001 models , not sure but i see in the last picture of this tutorial you have the white piece left in the drive. it is located behind the cd rom part near the top of the psp where the 2 x holes are. it sucks cause it dont close properly without the white piece and theres also 1 of the 2 springs not mentioned in this tutorial neither im trying to figure out where it goes. But thanks for this guide as it has helped me alot..
Ken
Kenneth A - Responder
Someone found the location of the missing spring? Haven’t figured it out yet…
tanja-stephan -
This has too many extra steps. If you’re *just* taking out the UMD drive, you only need to follow these sections: battery, casing, LCD screen, UMD drive. This guide should really just be called “how to completely disassemble your PSP 3000”.
Christopher Dickinson - Responder
What about removing the UMD trigger? I didn’t see it anywhere in this tutorial. Please help.
C Rad - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 35
Últimos 30 dias: 161
Duração total: 28,310
