Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Guide for removing the power board in a Sony PSP-3000
O que você precisa
Place the PSP face down and locate the battery cover on the left side of the device.
Lift and remove the battery cover to reveal the battery.
Remove the battery.
Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
Push the homebar to the right to release the tab located on the right side of the LCD screen.
Using a spudger, lift up the lock and remove the ribbon cable from the motherboard
4 outras pessoas executaram este guia.
