Ir para o conteúdo principal
PSP 300x Front Casing Replacement
O que você precisa
  1. PSP 300x Front Casing Replacement, Battery: passo 1, imagem 1 %32 PSP 300x Front Casing Replacement, Battery: passo 1, imagem 2 %32 PSP 300x Front Casing Replacement, Battery: passo 1, imagem 3 %32
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x Front Casing Replacement, Front Casing: passo 2, imagem 1 %32
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x Front Casing Replacement: passo 3, imagem 1 %32 PSP 300x Front Casing Replacement: passo 3, imagem 2 %32
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x Front Casing Replacement: passo 4, imagem 1 %32
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x Front Casing Replacement: passo 5, imagem 1 %32
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x Front Casing Replacement: passo 6, imagem 1 %32 PSP 300x Front Casing Replacement: passo 6, imagem 2 %32
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
Conclusão
33 outras pessoas executaram este guia.
kbrunner
Membro desde: 11/05/09
96 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 19-2, Maness Fall 2009 Membro de Cal Poly, Team 19-2, Maness Fall 2009
CPSU-MANESS-F09S19G2
3 Membros
Autoria de 13 guias
1Comentário do guia
This is only the faceplate, not a casing replacement, come on
Dick - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 59
Últimos 30 dias: 320
Ao todo: 23,464
