Ir para o conteúdo principal
PSP 1000 LCD Screen Replacement
O que você precisa
  1. PSP 1000 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 LCD Screen Replacement: passo 2, imagem 1 %32 PSP 1000 LCD Screen Replacement: passo 2, imagem 2 %32
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
  3. PSP 1000 LCD Screen Replacement: passo 3, imagem 1 %32 PSP 1000 LCD Screen Replacement: passo 3, imagem 2 %32
    • Using your finger, remove the battery upwards from the system as shown.
  4. PSP 1000 LCD Screen Replacement, Front Casing: passo 4, imagem 1 %32 PSP 1000 LCD Screen Replacement, Front Casing: passo 4, imagem 2 %32
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
  5. PSP 1000 LCD Screen Replacement: passo 5, imagem 1 %32
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 LCD Screen Replacement: passo 6, imagem 1 %32 PSP 1000 LCD Screen Replacement: passo 6, imagem 2 %32
    • Gently separate the outer plastic casing from the rest of the system as shown.
  7. PSP 1000 LCD Screen Replacement, LCD Screen: passo 7, imagem 1 %32
    • The Button Board, at the base of the LCD Screen, is held by two clips.
    • Pry these clips over the nubs using a PSP opening tool. This will release the clips.
    • The Button Board is still attatched to the PSP by a ribbon cable!
  8. PSP 1000 LCD Screen Replacement: passo 8, imagem 1 %32 PSP 1000 LCD Screen Replacement: passo 8, imagem 2 %32 PSP 1000 LCD Screen Replacement: passo 8, imagem 3 %32
    • The Button Board Ribbon Cable is held down with a latch. Lift the latch open, away from the ribbon cable.
    • Pull the cable away from the latch.
  9. PSP 1000 LCD Screen Replacement: passo 9, imagem 1 %32 PSP 1000 LCD Screen Replacement: passo 9, imagem 2 %32
    • The LCD Screen is held by the LCD Frame with similar clips. Slide a thin tool between the clip and the screen and gently pry them apart while beginning to lift the screen.
  10. PSP 1000 LCD Screen Replacement: passo 10, imagem 1 %32
    • The LCD screen is still attached with ribbon cables. Gently lift up the LCD screen so you do not break them.
  11. PSP 1000 LCD Screen Replacement: passo 11, imagem 1 %32 PSP 1000 LCD Screen Replacement: passo 11, imagem 2 %32 PSP 1000 LCD Screen Replacement: passo 11, imagem 3 %32
    • The thin Ribbon Cable opens from the opposite side in which the Ribbon Cable enters. Open up the latch towards the Ribbon Cable. The latch will pull up and release the ribbon cable. Put your tool behind the black part, then pry up the black piece of plastic.
    • The wide Ribbon Cable opens from the same side in which the Ribbon Cable attatches, and opens away from the cable.
    • Both of these latches are the black pieces.
    • Gently pull the ribbon cables away from the latches. The LCD screen can now be removed.
    • When reassembling - be careful which way you push the latches. The small one is very easy to break.
Linha de Chegada
74 outras pessoas executaram este guia.
Henry Lee
Membro desde: 01/14/10
833 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 5-6, Forte Winter 2010 Membro de Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 Membros
Autoria de 34 guias
8 comentários
I broke one of the laches....helppp!!!!
janet - Responder
This is not easy...I tore up the outer casing trying to do this. I better see money in the mail for this
Justin Autrey - Responder
My Sony PSP has just stop coming on
lil bao - Responder
People!! If you weren't gifted in screws and bolts, then bring your console to a repair shop. Seriously blaming this for your Dick Fingers?
janisfranckevics - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 48
Últimos 7 dias: 229
Últimos 30 dias: 769
Ao todo: 86,847
