Ir para o conteúdo principal
PSP 1000 Front Casing Replacement
O que você precisa
  1. PSP 1000 Front Casing Replacement, Battery: passo 1, imagem 1 %32
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 Front Casing Replacement: passo 2, imagem 1 %32 PSP 1000 Front Casing Replacement: passo 2, imagem 2 %32
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
  3. PSP 1000 Front Casing Replacement: passo 3, imagem 1 %32 PSP 1000 Front Casing Replacement: passo 3, imagem 2 %32
    • Using your finger, remove the battery upwards from the system as shown.
  4. PSP 1000 Front Casing Replacement, Front Casing: passo 4, imagem 1 %32 PSP 1000 Front Casing Replacement, Front Casing: passo 4, imagem 2 %32
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
  5. PSP 1000 Front Casing Replacement: passo 5, imagem 1 %32
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 Front Casing Replacement: passo 6, imagem 1 %32 PSP 1000 Front Casing Replacement: passo 6, imagem 2 %32
    • Gently separate the outer plastic casing from the rest of the system as shown.
Conclusão
35 outras pessoas executaram este guia.
Henry Lee
Membro desde: 01/14/10
866 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 5-6, Forte Winter 2010 Membro de Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 Membros
Autoria de 34 guias
3Comentários do guia
Thank you! Awesome help!
Jay Vee - Responder
My psp is updating then psp is fallen down and battery comeout so please help me please thank you
Bye
National Nazeer - Responder
i also made a video on this for anyone who needs to do it that way.
https://www.youtube.com/watch?v=EIAaJyIx...
DAS Repair - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 72
Últimos 30 dias: 329
Ao todo: 48,239
