Introdução
Note::: taking apart your device may void the warranty on the device, please proceed with caution and consider having it sent in first if possible to be worked on by the company. This guide's goal is to help you replace the buttons on the PS Vita Slim. You may need to do this if the buttons get sticky, worn out, or damaged. The buttons should be a simple procedure. As long as you take your time and you carefully interact with the system you should be fine.
O que você precisa
All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
There are four screws on the back of the device, remove them as shown.
The next step is to take the ribbon off of the green casing on the left.
Then simply unscrew the two screws holding down the green casing using a J00 bit from the iFixit pro toolkit, they should both be 6.35 mm .
Now simply raise the last restraint, a metal bar that is holding the casing down. Once it has been removed you can take off the green casing.
5 outras pessoas executaram este guia.
3 comentários
the ps button doesn't work, i have replaced the left d pad but it still doesn't work, where is the possible damage?
Likely the board. Same thing happened to me, but with the square button. Button replacement didn't work and I had to replace the right board.
Slight correction on Step 8. This should be a J000, not 00. You'll end up stripping the screws if you're not careful.
