Introdução
This guide's goal is to help the user to replace the battery of a PS Vita Slim if the battery is faulty or has some other kind of problem.
O que você precisa
All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
There are four screws on the back of the device, remove them as shown.
Using the spudger, carefully pry the battery connector upwards out of the socket. Do not fully remove the battery yet.
Now using the tweezers, carefully remove the ribbon connecting the battery from the hardware.
10 outras pessoas executaram este guia.
Um comentário
Whilst tearing down my PCH-2016 model PS Vita Slim I have noticed that there is also a screw in the cartridge area that needs to be removed to remove the back panel.
