Ir para o conteúdo principal
PRS Guitar Pickups Replacement
O que você precisa
  1. PRS Guitar Pickups Replacement, Pickups: passo 1, imagem 1 %32 PRS Guitar Pickups Replacement, Pickups: passo 1, imagem 2 %32
    • Loosen all of the strings until they can be pulled out of the tuners.
    • Pull the strings through the bridge and out of the back side of the guitar.
  2. PRS Guitar Pickups Replacement: passo 2, imagem 1 %32 PRS Guitar Pickups Replacement: passo 2, imagem 2 %32
    • Using a Phillips head screwdriver, unscrew the back plate, revealing the pickup wiring.
  3. PRS Guitar Pickups Replacement: passo 3, imagem 1 %32
    • Take note of the wiring before desoldering the wires.
    • Begin desoldering the pickup wires.
    • Take care when soldering, as the tip is very hot.
  4. PRS Guitar Pickups Replacement: passo 4, imagem 1 %32 PRS Guitar Pickups Replacement: passo 4, imagem 2 %32
    • Turn the guitar face up and unscrew both of the pickups.
    • Take the pickups out of the guitar.
  5. PRS Guitar Pickups Replacement: passo 5, imagem 1 %32 PRS Guitar Pickups Replacement: passo 5, imagem 2 %32
    • Refer to the wiring arrangements you took note of as well as the wiring manual that came with your new pickups.
    • Run the new pickups back through the guitar with the wires guided through the back plate.
    • Carefully begin soldering the new pickup wires back together.
  6. PRS Guitar Pickups Replacement: passo 6, imagem 1 %32
    • This is a good opportunity to clean the guitar.
    • Begin restringing the guitar with new strings of your preference.
    • Using a string/wire cutter and cut excess strings from tuners.
Linha de Chegada
Nathan Kevil
Membro desde: 02/25/21
141 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 50
Duração total: 495
