Ir para o conteúdo principal
POLAR CADENCE SENSOR BLUETOOTH® SMART Battery replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
  1. POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, The sensor: passo 1, imagem 1 %32
    • Removed Cadence Senosor from frame
  2. POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Cutting open the Sensor: passo 2, imagem 1 %32 POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Cutting open the Sensor: passo 2, imagem 2 %32 POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Cutting open the Sensor: passo 2, imagem 3 %32
    • Either use hacksaw or Dremel to cut open downside of the sensor. Use the carve of the body for guidance.
  3. POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Behind the circuit board lies the...: passo 3, imagem 1 %32 POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Behind the circuit board lies the...: passo 3, imagem 2 %32 POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Behind the circuit board lies the...: passo 3, imagem 3 %32
    • After cutting the downside, sensor can easily be opened. Remove circuit board with care not to break the pin. Remove copper clamp with tweezers.
  4. POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Replacing the battery: passo 4, imagem 1 %32
    • Replace battery
    • Move magnet close to diode. Flashing indicates successful replacement
  5. POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Gluing it up: passo 6, imagem 1 %32 POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Gluing it up: passo 6, imagem 2 %32
    • Glue it up (maybe nicer than I did)
    • Second functional test with glued chasis
Conclusão
To reassemble your device, follow these instructions in reverse order
Um agradecimento especial a esses tradutores:
de en
100%
jeremyfitz está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Sebastian Stechl
Membro desde: 04/20/14
195 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 34
