Ir para o conteúdo principal
PENTAX OPTIO 330 Internal Battery replacement
O que você precisa
  1. PENTAX OPTIO 330 Internal Battery replacement, Remove rear bloc: passo 1, imagem 1 %32
    • remove the two 2.5mm screw of the left side
  2. PENTAX OPTIO 330 Internal Battery replacement, Remove rear bloc: passo 2, imagem 1 %32
    • Remove two 4mm screw of the right side
  3. PENTAX OPTIO 330 Internal Battery replacement, Remove rear bloc: passo 3, imagem 1 %32
    • remove 2mm screw
    • remove 3mm screw
    • remove the three 3.5mm screw
  4. PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: passo 4, imagem 1 %32 PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: passo 4, imagem 2 %32 PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: passo 4, imagem 3 %32
    • Open the memory protection
    • Remove gently the rear cover
    • When re-assembly take care to the thin tabs
  5. PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: passo 5, imagem 1 %32 PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: passo 5, imagem 2 %32
    • this part can fall down. So rome it before next step.
  6. PENTAX OPTIO 330 Internal Battery replacement, Front cover remove: passo 6, imagem 1 %32 PENTAX OPTIO 330 Internal Battery replacement, Front cover remove: passo 6, imagem 2 %32 PENTAX OPTIO 330 Internal Battery replacement, Front cover remove: passo 6, imagem 3 %32
    • Insérez ici votre traduction
  7. PENTAX OPTIO 330 Internal Battery replacement: passo 7, imagem 1 %32
    • Remove four screw
    • unplug the two Flex
  8. PENTAX OPTIO 330 Internal Battery replacement, Battery replacement: passo 8, imagem 1 %32 PENTAX OPTIO 330 Internal Battery replacement, Battery replacement: passo 8, imagem 2 %32
    • This connector is directly to the board
    • This Flex connector need to be unplug
    • The 321 battery is there
    • You can add some thermal glue to fix the battery
    • I did it with a small piece of scotch
Conclusão
To re-assembly your device follow the step backward
Um agradecimento especial a esses tradutores:
fr en
100%
Bertrand PIGEARD está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Bertrand PIGEARD
Membro desde: 12/11/21
235 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 130
