Introdução
If you are having trouble with turning on your PDP Victrix Pro BFG Controller or having trigger problems, this guide will help you. This guide takes you through how to open up your controller, replace your batteries, and replace your triggers. If you have any problems or need to fix anything else related to this controller, please visit our troubleshooting page.
O que você precisa
Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
Remove the joystick/button modules from the controller.
4 outras pessoas executaram este guia.
4Comentários do guia
Only guide I could find to get this controller apart for my son. Now have to find someone to resolder the USB c port.
